Calculating System Efficiency for Trough and Tower Systems
14 Nov 2012 16:57 #306 by Paul Gilman
Are you describing variables that you see in SAM, or are you asking me how to calculate those values from SAM variables?
If you are describing variables in SAM, can you tell me specifically where you see them?
  • vp16
  • Junior Member
  • Junior Member
14 Nov 2012 19:20 #307 by vp16
I want to calculate it from SAM variables. How to do that.?
  • vp16
  • Junior Member
  • Junior Member
17 Nov 2012 17:35 #308 by vp16
Can you describe how to calculate the annual average and peak solar to electric conversion efficiency for tower and trough systems and also solar field efficiency.
I have done some calculations but would like to confirm from your side to avoid confusion and miscalculation.
19 Nov 2012 17:36 #309 by Paul Gilman
Please feel free to post your equations to see if someone is interested in checking your work.
  • vp16
  • Junior Member
  • Junior Member
27 Nov 2012 13:17 #310 by vp16
The annual average solar field efficiency: Energy output from soalr field MWh/(DNI kWh/m2 * aperture area m2)
Annual Solar to electric Efficiency: Annual Energy Output/(DNI kWh/m2 * aperture area m2)
Is these formulas correct.? Also any ideas on how to calculate peak of these efficiencies.?
Please let me know.
  • vp16
  • Junior Member
  • Junior Member
28 Nov 2012 17:36 #311 by vp16
Please let me know the correct formulas in case they are incorrect.
SAM Beta version has only 2 days left from expiring, so I might have to run again for some values if these are not the correct ones indeed.
