Diffuse Sky Model
  • csmichels
22 Jan 2015 09:10 #2981 by csmichels
Diffuse Sky Model was created by csmichels
Dears,
I've seen that the new SAM includes the option of calculating POA irradiance using total+diffuse components. Is there any documentation to see what method does it use?
This is very useful, since some times the only data I have available is GHI and DHI (before, i calculated mathematically the beam component using the sun's position and filtering for low cos values).
22 Jan 2015 11:56 #2982 by Paul Gilman
Replied by Paul Gilman on topic Diffuse Sky Model
The draft PV reference manual available on the Performance Model Documentation page includes a description of the incident irradiance calculations.
  • csmichels
26 Jan 2015 13:16 #2983 by csmichels
Replied by csmichels on topic Diffuse Sky Model
I've revised the document but it only explains the two old calculation modes:
- Beam + Diffuse
- Global + Beam
But SAM the new SAM release can do PV calculation using only Global and Diffuse. I could not find any reference for this calculation on that document.
Sebastian
26 Jan 2015 14:30 #2984 by Paul Gilman
Dear Sebastian,
Ah yes. Thank you for the clarification. I did not read your original post carefully enough.
When you run the detailed photovoltaic model in "total and diffuse" mode, SAM uses the following equation to calculate the beam (direct normal) irradiance from the total and diffuse irradiance values in the weather file:
ibeam = (gh - df) / cos(z)
Where ibeam=beam, gh=total horizontal in W/m2 from weather file, df=diffuse horizontal in W/m2 from weather file, and z=sun zenith angle in degrees.
If the result is greater than 1500 W/m2, it sets ibeam = 1500. If it is less than zero, it sets ibeam = 0.
  • csmichels
27 Jan 2015 07:01 #2985 by csmichels
Great,
I was doing the same calculation manually. This is a good option when DNI values are not available.
KR
