Frenel, diathermic oil
  • valeria
20 Jan 2015 08:22 #2965 by valeria
Frenel, diathermic oil was created by valeria
hello! sorry, I'm new in SAM. Please, I would like to know if it is possible to simulate fresnel solar plant with riathermic oil as heat transfer fluid.
Thank you very much.
Valeria
20 Jan 2015 14:20 #2966 by Paul Gilman
Replied by Paul Gilman on topic Frenel, diathermic oil
Dear Valeria,
Yes, you can model a linear Fresnel plant with an oil as the heat transfer fluid. To do so, choose an oil for the fluid HTF on the Solar Field page, and adjust the other parameters as appropriate.
  • valeria
21 Jan 2015 10:39 #2967 by valeria
Replied by valeria on topic Frenel, diathermic oil
Hello! thanks for you answer! So I should select Fresnel with salt and then use oil?
Thanks Paul!
Best regards
Valeria
21 Jan 2015 10:54 #2968 by Paul Gilman
Dear Valeria,
Yes. The choose the "molten salt" linear Fresnel model to model a system that uses either a salt or oil as the heat transfer material.
