Parametric Analysis Crashing
- noahfs
18 Dec 2014 08:18 #2853
by noahfs
Parametric Analysis Crashing was created by noahfs
I am trying to run a parametric simulation for a PV single user system. I have three variables in the analysis but realized I need to remove one. When I attempt to remove one in the "Quick Setup" section, SAM crashes. This happens each time. Is there some I can do to avoid this crash?
18 Dec 2014 11:49 #2854
Replied by Paul Gilman on topic Parametric Analysis Crashing
Dear Noah,
I was able to replicate that crash -- it's something we will fix for the January update. Thank you for helping us find that bug.
In the meantime, I think you can remove parametric input variables and avoid the crash by clicking Inputs and clearing the check boxes for the variables you want to remove.
- rgh1729
02 Dec 2015 06:43 #2855
by rgh1729
Replied by rgh1729 on topic Parametric Analysis Crashing
I'm having the same problem. What was the outcome of this investigation?
03 Dec 2015 10:03 #2856
This issue was resolved in SAM 2015.1.30. If you are using the latest version of SAM, you should not have any trouble removing variables from parametric simulation setup.
