"Download" feature gives erroneous error message
- soular
11 Dec 2014 19:17 #2821
by soular
"Download" feature gives erroneous error message was created by soular
I need to run SAM using the PV Watts model with single year weather data for 2006, for several locations. I click on "Download", select 2006, and enter a city name (e.g., Boston, MA or Hartford, MA). I get error messages like the following, no matter what city I choose:
Error: the selection 'Boston MA_2006' was not found in the available choices.
Then, another notice came up:
error applying library entry Boston MA_2006\
The strange thing is that then I get a message telling me that the data file was downloaded, and in fact it was. I'm able to simulate with any of the files I tried, and it seems to work fine.
12 Dec 2014 11:16 #2822
Replied by Paul Gilman on topic "Download" feature gives erroneous error message
I just tried the steps you describe and was able to download a 2006 file for Boston.
It is possible that the Solar Prospector server was not responding at the moment you tried the download, or that there is something about your internet connection that is preventing SAM from communicating with the server.
Please try one more time, and if it still does not work, you can download the file directly from the Solar Prospector website .
- soular
13 Dec 2014 15:39 #2823
by soular
Replied by soular on topic "Download" feature gives erroneous error message
Thanks Paul, but I think you misunderstood the problem. It's not that the file isn't downloaded -- it IS downloaded but the erroneous messages cause the user to think it hasn't been. In the download process, error messages appear saying a) it couldn't be found (presumably at Solar Prospector) and b) the library entry couldn't be applied. Refreshing the library causes the file to be listed in list at the top of the screen. So I believe the error messages are wrong.
16 Dec 2014 10:23 #2824
Thank you for following up. I tested this again and was able to replicate the issue as you describe it. We are investigating and will fix it for the January update.
08 Jan 2015 10:04 #2825
This is a problem with the weather file folder settings on some computers. We have fixed the problem for the next update. Thank you for helping us identify the problem.
In the meantime, you can work around the problem as follows:
On the Location and Resource page, click Folder settings.
Under Folder for Downloaded Solar Data Files, click the ellipses button (...).
Navigate to a folder where you would like SAM to store downloaded weather files. It must be a folder that you can access.
