Change in start hour from 1 am to midnight in the change from version 2014.1.14 to 2014.11.24
  • williampaulbell
07 Dec 2014 23:07 #2811 by williampaulbell
Dear Paul
Could you answer the following query regarding the change in start hour from 1 am to midnight in the change from version 2014.1.14 and 2014.11.24 please?
I am using all the defaults for the technology "CSP linear Fresnel direct steam" with "No financial model" option.
The TMY3 input file and SAM's output, the Hourly "Electrical Source - Gross Output(MWh)" are attached.
The input TMY3 starts at 1 am but SAM's output starts at midnight.
---1. Should I re-base the TMY3 input files to start at midnight?
---2. Does SAM 2014.11.24 recognise the minutes past the hour in the TMY input files?
Regards
William Bell
08 Dec 2014 13:54 #2812 by Paul Gilman
Dear William,
1. For hourly weather data, SAM assumes that the first row of data is for the hour beginning at 12 a.m. on January 1 and ending at 1 a.m. The TMY3 convention is for Hour 1 to be for the hour ending at 1 a.m. on January 1, so the two are equivalent. The time stamp for the first row in tables on the SAM results page is "Jan 1, 12:00 am" indicating the time at the beginning of the time step. You do not need to modify your file for SAM to read it correctly.
3. SAM does not read the minute information in the TMY3 file. For sun angle calculations it uses the midpoint of the hour (by setting the minute value to 30 for all hours of the year). For the new SAM CSV format, SAM uses the midpoint of the time step for the sun position calculation unless you specify values in a 'Minute' column, in which case it uses the minute value you specify.
