where can i find the total annual thermal output
- nwepdi2676
15 Feb 2012 20:17 #276
by nwepdi2676
where can i find the total annual thermal output was created by nwepdi2676
hi
everyone, i am a newcome to SAM.
how can i get the total annual thermal output (MWHt) in the rusult? i use the sam in parabolic trough physical mode.
thanks.
thanks.
- nwepdi2676
15 Feb 2012 20:22 #277
by nwepdi2676
Replied by nwepdi2676 on topic where can i find the total annual thermal output
in the result page, data tables/metric/net annual energy item,the data is
2.06468e+007,which has no unit.
16 Feb 2012 09:39 #278
Replied by Paul Gilman on topic where can i find the total annual thermal output
The values displayed in the data tables under Metrics are the same as those that appear in the Metrics table at the bottom left corner of the Main window. The Metrics table shows the values and their units. Net annual energy is in kWh.
The annual thermal output values are available in the data table under Single Values. For example, "Q Field Output, Annual" is the solar field output in MWh, and "Thermal Energy to Power Block" is the total thermal energy delivered to the power block over the year in MWh.
