Formual 61 in DRAFT pvsam manual
  • sunup
04 Oct 2014 10:25 #2587 by sunup
Formual 61 in DRAFT pvsam manual was created by sunup
Is the formal correct it reads
Id = Di + Dc + Dc
06 Oct 2014 11:48 #2588 by Paul Gilman
Replied by Paul Gilman on topic Formual 61 in DRAFT pvsam manual
That equation is not correct. It should read:
Id = Di + Dc + Dh
The incident diffuse irradiance for the Perez model is the sum of the isotropic, circumsolar, and horizon brightening components of the sky diffuse irradiance.
Thank you for pointing out the typo.
  • sunup
06 Oct 2014 13:27 #2589 by sunup
Replied by sunup on topic Formual 61 in DRAFT pvsam manual
I thought so. Got a couple more 8-).
Formula 20. ha is lower case (upper case in 17)
Formula 22 should not be arrcos a just a.
The HAR term in 24 and 25 is a bit messed up
I think it should be 180/PI 1/15 arccos HAR
lambda needs to be defined or substituted with lon
Page 14. Formula 7 description 'sunce' instead of since.
08 Oct 2014 10:21 #2590 by Paul Gilman
Thanks for these. Please let me know if you notice any more errors.
  • sunup
08 Oct 2014 11:48 #2591 by sunup
Would you rather have a annotated PDF ?
08 Oct 2014 11:57 #2592 by Paul Gilman
That would be great. You can email it to me at sam dot support at nrel dot gov.
