Reporting Out Parametric Analysis Results
  • mhdraper
02 Jun 2014 18:22 #2370 by mhdraper
How can you set up parametric analysis to report out results for independent variables in same cash flow spreadsheet
In my analysis I have input a range of systems costs in $/W to reflect varying reported total project costs. There are four different cases set in the project file.
When the analysis is run, the cash flow results are only shown for highest value.
Graphs, on the other hand, display varied results based on range of $/W costs as shown on the X value.
Should I employ the sensitivity analysis as alternative?
I hope I'm explaining myself well enough to warrant a reply.
03 Jun 2014 10:56 #2371 by Paul Gilman
Replied by Paul Gilman on topic Reporting Out Parametric Analysis Results
To display a table of cash flow variables for a parametric analysis:
  1. Click Tables on the Results page.
  2. For Choose Simulation, click Parametric Set 1.
  3. Expand the Annual Data list.
  4. Check the variable names to build the table.
You'll also find some annual variables in the Data: 25 years list.
Once you've built your table, you can export it by clicking Copy to clipboard, Save as CSV, or Send to Exel.
  • mhdraper
03 Jun 2014 13:02 #2372 by mhdraper
Replied by mhdraper on topic Reporting Out Parametric Analysis Results
Exactly what I needed. Thanks!
