GHI, DHI to DNI
- csmichels
26 May 2014 16:14 #2362
by csmichels
GHI, DHI to DNI was created by csmichels
Dear All,
Im using SAM for calculating the long term yield of a PV plant here in Chile.
We only have long term satellite data for GHI and DHI (diffuse horizontal).
I know there is a mathematical relashionship between GHI,DHI and beam (DNI. Is it possible to calculate DNI from these two straight forward? What about low elevation angles, since there might be a division by zero.
Do you have a recomended method in order to get DNI from the other two and use SAM?
Best Regards.
Sebastian.
Best Regards.
Sebastian.
27 May 2014 15:42 #2363
Replied by Paul Gilman on topic GHI, DHI to DNI
Dear Sebastian,
There are a couple of discussions on this topic that might help: Best regards,
- csmichels
02 Jun 2014 15:24 #2364
by csmichels
Replied by csmichels on topic GHI, DHI to DNI
I've forgot to mention that I was looking at the DISC model as an alternative for estimating DNI. Nevertheless this way I'm leaving the DHI data out, and doing an assesment just based on GHI.
I would like to have some insight from more experienced engineers if its better to do this and use only GHI or estimate DNI through mathematical formulas.
Bests
Bests
