Zero Annual Energy (solar PV)
- powertec
08 Apr 2014 13:34 #2258
by powertec
Zero Annual Energy (solar PV) was created by powertec
I am not able to see annual PV production. First time using this model, though have used others. I must not have some feature engaged. Can you review my file, or offer a suggestion?
09 Apr 2014 11:09 #2259
Replied by Paul Gilman on topic Zero Annual Energy (solar PV)
Please the Getting Started section in SAM's Help system , and make sure you followed all of the steps there. (You can also find the topic from SAM's Help menu, or by pressing the F1 key in Windows, or Command-? in OS X.)
If you still have trouble, feel free to attach a copy of your SAM file (.zsam) to your original message, and I will try to help.
- powertec
10 Apr 2014 10:10 #2260
by powertec
Replied by powertec on topic Zero Annual Energy (solar PV)
Hello Paul,
Thank you for your message and offer to review my file. I will try your suggestions to work with the programs help topics and will let you know if I need further assistance. FYI, I can get the solar DC output to display, just not the solar AC monthly output.
James
James
10 Apr 2014 14:45 #2261
Dear James,
Please be sure that you did not set the value of one of the AC derate factors (on the Array page for the Flat Plate PV model) to zero. An AC derate factor of zero would cause the AC output to be zero when the DC output is not zero.
- powertec
10 Apr 2014 17:21 #2262
by powertec
That was it. I had both the step up transformer loss and Total interconnection de-rate set at zero. Once I changed those the monthly solar output populated. Thanks for all you help.
James
James
