Tower System - Influence of Circum Solar Ratio
- MHess
27 Jan 2012 07:27 #242
by MHess
Tower System - Influence of Circum Solar Ratio was created by MHess
We have 2 questions regarding the heliostat field efficiency calculation wihtin the Tower model :
- Do you take into account the effect of the half angle of the sun (circumsolar)?
- how the shapes (slight focalization) of the heliostat mirrors have been taken into account?
Thanking you in advance,
Regards
Regards
06 Feb 2012 11:21 #243
Replied by Paul Gilman on topic Tower System - Influence of Circum Solar Ratio
The sun shape model used in DELSOL3 is a limb-darkened sun with the following equation:
Where r is the radial distance from the centroid of the sun, and R is the maximum angle subtended, equal to 4.65*10^-3 in DELSOL.
Each heliostat is assumed to be focused and canted at a focal length equal to the distance from the heliostat to the receiver.
- MHess
07 Feb 2012 05:38 #244
by MHess
Replied by MHess on topic Tower System - Influence of Circum Solar Ratio
Thanks for your very clear answer
Best regards
Best regards
