Utility Rate Library
- ddc123
26 Jan 2012 05:45 #240
by ddc123
Utility Rate Library was created by ddc123
Is there a way to pull utility rates from the utility rate library instead of the online website.
01 Feb 2012 12:27 #241
Replied by Paul Gilman on topic Utility Rate Library
SAM does not include a built-in library of utility rates. You can either specify the rate structure by hand, or import a rate from the OpenEI database (
en.openei.org/wiki/Gateway:Utilities
(You specify the utility structure on the Utility Rate page, which is only available for the residential and commercial financing options.)
