Energy value question
- Tom Durston
27 Feb 2014 16:15 #2185
by Tom Durston
Energy value question was created by Tom Durston
In my project, in the cash flow spreadsheet I don't understand the Energy Value number. This is a residential flat plate PV project where the year 0 energy = 10,760 kWh and the year 0 energy value = $3,449.82. This equates to $0.3206/kWh, which would be mostly in tier 3 rates, but the energy production and the useage of 10,241 kWh/year correspond mostly to tier 1. I entered hourly data from the Sacramento sample file.
Could you explain what is happening in this project? This is my first project.
Thanks very much.
Thanks very much.
03 Mar 2014 10:22 #2186
Replied by Paul Gilman on topic Energy value question
Dear Tom,
Unfortunately, SAM's tiered rate model does not accumulate kWh on a monthly basis, so it does not correctly model tiered rates. It treats the tiers as hourly tiers instead of monthly tiers.
In your file, for example, the Tier 3 rate of $0.32377/kWh will only apply in hours that the hourly usage exceeds 30.6 kWh.
We plan to fix this behavior in the next version of SAM, which we hope to release in the Fall of 2014.
- Tom Durston
04 Mar 2014 16:47 #2187
by Tom Durston
Replied by Tom Durston on topic Energy value question
Thanks, Paul. Understanding this, I can export the spreadsheet and adjust the energy value using separate calculations.
- sean2249
20 Jun 2014 19:48 #2188
by sean2249
Replied by sean2249 on topic Energy value question
Just I ask..
How to calculate the energy value?
Like, Energy output(kWh) x utility rate($/kWh) = Energy Value
23 Jun 2014 09:57 #2189
I am not sure what your question is. You can export those variables' values from the cash flow table if you want to see how SAM calculates the energy value metric.
