Comparing annualized energy price multipliers
  • awarudkar
19 Feb 2014 09:37 #2165 by awarudkar
I built 3 models for a 3MWac PV plant. Fixed tilt (20degrees), SAT (0 degrees) and SAT(20 degree tilt). The annualized price multiplier for Fixed and SAT (20 degree) come out to be same... but a much higher for SAT (zero degrees). IS this normal ? What is the logic behind this ? {location Southern California}
19 Feb 2014 09:56 #2166 by Paul Gilman
Replied by Paul Gilman on topic Comparing annualized energy price multipliers
I'm not sure what you mean by "annualized price multiplier." Can you tell me which SAM result you are describing, or how you are calculating the multiplier?
Also, if you can attach your .zsam file to your original post (click Edit above, and then scroll to the middle of the page to attach the file), I'll have a better chance of answering your question.
  • awarudkar
19 Feb 2014 10:50 #2167 by awarudkar
Replied by awarudkar on topic Comparing annualized energy price multipliers
Paul.. when I run the model and copy the results in an excel .. my top three rows are as follows :
Year 0 1 2 3 4 5 6
Energy (kWh) 0 6522718 6490104 6457654 6425366 6393239 6361273
Energy Price ($/kWh) 0 0.108 0.109 0.11 0.112 0.113 0.114
Energy Value ($) 0 706428.63 709925.44 713439.56 716971.13 720520.13 724086.69
I think the row which says Energy Price ($/kwh) is some annualized average of (PPC price + TOD multipliers) ... it is this number that comes same for Fixed tilt and SAT-20degree tilt ... but higher for SAT-zerodegree ... Does that make sense ?
20 Feb 2014 10:05 #2168 by Paul Gilman
That helps a little, but without seeing what the time-of-delivery (TOD) multipliers are, I can't be sure what is causing the effect you are seeing.
Is the output of the system with the horizontal array higher than for the tilted arrays in hours when the multipliers are also high? Perhaps the timing of the multipliers favors an array that maximizes output during the summer months when a horizontal array produces more electricity than a tilted one.
