Always errors and shutsdown when running Kwajelin Atol
  • hboulley
21 Jan 2014 09:58 #2123 by hboulley
I've downloaded the Kwajelin EPW file and uploaded into the SAM and set all my parameters.
Every time I try to run the analysis, the SAM errors and closes.
I've updated to the latest version and still have this issue.
Any thoughts?
21 Jan 2014 10:50 #2124 by Paul Gilman
That file has a problem with the header that causes SAM to close: The "state" column is empty. If you replace it with a hyphen, it should work.
I've attached a modified file to your original post that should fix the problem.
We will update the weather file reader in a future version of SAM to avoid this issue.
  • hboulley
18 Jun 2014 00:06 #2125 by hboulley
Thanks .. I missed this one! Appreciate it
