PV report picks up bogus data
  • John Barnes
09 Jan 2014 11:16 #2073 by John Barnes
PV report picks up bogus data was created by John Barnes
Hello Paul,
Paul in the next rev. could this mistake of picking up a bogus PPA rate in the file be fixed?
Hope the year is off to a good start for you.
John Barnes
jbarnes@solarlandpartners.com
09 Jan 2014 12:38 #2074 by Paul Gilman
Replied by Paul Gilman on topic PV report picks up bogus data
Dear John,
Yes, I fixed the error, and we will include the fix in the next version of SAM. The problem applies to reports for photovoltaic systems with either the Commercial PPA, Utility IPP, or Single Owner financial model when the financial solution mode is "Specify PPA Price."
In the meantime, here is a workaround solution to fix the problem in your copy of SAM:
1. Download the file PV - Utility IPP - Commercial PPA - Single Owner.samreport that I attached to your original post above.
2. Replace the file of the same name in the \exelib\reports folder in your SAM installation (c:\SAM\2013.9.20\exelib\reports by default in Windows).
Thank you for pointing out the error.
