Generic CSP in southern hemisphere
- hmb
20 Dec 2013 06:22 #2052
by hmb
Generic CSP in southern hemisphere was created by hmb
I am pretty unexperienced in using SAM, so please apologize for my question in advance.
I am using SAM 2013.9.20 to model a generic CSP plant in the southern hemisphere. If I use the default settings, an alteration of the sample weather file to a negative latitude, immediately leads to the following error:
SVAL LOOKUP ERROR trnsys.user_trdsrc
As solar field optical efficiency data is defined from -180° to 180° this shouldn't be the problem, right? So, where do I have to search to solve this problem?
Thank you very much in advance.
- hmb
30 Dec 2013 07:41 #2053
by hmb
Replied by hmb on topic Generic CSP in southern hemisphere
have I described my problem clearly? Is there a simple solution to it? I would appreciate any comment.
Best regards
Hannes
Best regards
Hannes
02 Jan 2014 12:35 #2054
Replied by Paul Gilman on topic Generic CSP in southern hemisphere
Dear Hannes,
We are looking into this issue, and I will get back to you as soon as I have an answer.
09 Jan 2014 11:05 #2055
Dear Hannes,
If I understand correctly, you are starting with a "sample weather file" for a location in the northern hemisphere, and modifying the file by changing only the latitude value in the file header. That will cause simulations to fail because SAM uses the latitude, longitude, and time stamp values to calculate hourly solar position angles, which will not be consistent with the solar radiation data for the original northern hemisphere location. For example, the solar radiation data on the summer solstice (June 21) will be for the longest day of the year instead of the shortest day of the year as it would be in the southern hemisphere.
You would be better off using a weather file for a southern hemisphere location. For example, there is a file for Alice Springs (Australia) among the files included with SAM. You can download weather files for other locations from one of the sites listed in SAM's Help system .
- hmb
15 Jan 2014 07:35 #2056
by hmb
thank you a lot for your answer. I did it as you said and I will go for the way you described.
Hannes
Hannes
