Small CSP Power Tower
- Nicole Blinco
04 Dec 2013 20:57 #2010
by Nicole Blinco
Small CSP Power Tower was created by Nicole Blinco
I am using the latest version of SAM to model a small 1.2MW (thermal) heliostat field with a 25m tower. The heliostat positions are defined in x-y coordinates and the field has overall dimensions of 110m X 70m. Using the 'CSP Molten Salt Power Tower' case and entering the appropriate field, tower and power cycle parameters the program returns results of zero for all relevant outputs, including thermal energy incident on receiver, thermal energy to power cycle and receiver mass flow rate. Do you have any ideas about what might be going wrong?
Thanks in advance.
Nicole
Thanks in advance.
Nicole
06 Dec 2013 11:00 #2011
Replied by Paul Gilman on topic Small CSP Power Tower
Dear Nicole,
Would you mind attaching a copy of the .zsam file to your original post? (Click Edit, and then scroll down to see the attachment options.)
11 Dec 2013 09:50 - 03 Aug 2022 11:15 #2012
Dear Nicole,
I have the following observations based on the file you emailed me:
1. You are modeling a solar field with heliostats one one side of the tower, which suggests the design is for a cavity receiver rather than the external receiver specified in SAM. To change the receiver to a cavity receiver, on the Tower and Receiver page, choose Cavity Receiver, and, because you are using your own heliostat layout, click No in the message asking about running the optimization wizard. Then, change the receiver dimensions in the Cavity Receiver box to the dimensions of your reciever.
2. In our tests with small power tower systems, the solar field characterization calculations seem to fail when the receiver design thermal power (shown as a calculated value on the Tower and Receiver page) is around 1 MWt or less. That's because the algorithms are designed for larger systems and we did not test them for smaller systems. We don't know exactly why the calculations fail, but are investigating. We can't promise a fix for this at the moment, but it is helpful for us to hear from people who want to model small tower systems to give us a sense of how many are affected by this limitation of SAM.
Last edit: 03 Aug 2022 11:15 by Paul Gilman.
- Nicole Blinco
11 Dec 2013 14:49 #2013
by Nicole Blinco
Replied by Nicole Blinco on topic Small CSP Power Tower
Thanks for your help Paul. The receiver we are trying to model is not a cavity receiver, it is external, but the shape and design is different to anything that is available in SAM. It may be that it is impossible to properly model the system for this reason.
