CSP Physical Through Model: Availabilty to get inside the regression model
- juanhaces
08 Nov 2013 09:13 #1916
by juanhaces
CSP Physical Through Model: Availabilty to get inside the regression model was created by juanhaces
I'm working with a project of CSP Power Plant with an direct storage. I'd like to know, whether it is possible, the way to know which kind of regression is implemented in the power block.
Exactly, I'd like to know:
- Would it be possible to adjust the model? I'd like to implement more extractions and sections for the turbine and a reheater to accurate our model. I have researched in the forum, website, the channel of youtube and the user guide, but unfortunately I haven't found anything to achieve the implementation.
- I have read in another question that the SDK for CSP is not yet implemented. Could you give us a date? sam.nrel.gov/content/when-will-sdk-csp-will-be-available
- Lastly, i'll be so glad, whether you are able to explain to us the cold startup. How does it work? Which kind of assumptions must be here taken into account? Are the assumptions the same of the control flow diagram of the Physical Through Model (Figure 31)?
Thank very much in advance!
Juan
Juan
11 Nov 2013 12:45 #1917
Replied by Paul Gilman on topic CSP Physical Through Model: Availabilty to get inside the regression model
- juanhaces
21 Nov 2013 09:26 #1918
by juanhaces
Replied by juanhaces on topic CSP Physical Through Model: Availabilty to get inside the regression model
I have been reading the codes with the notepad. I'd like to ask you about the library of TRNSYS 'csp_dtr_simctrl.trdsrc':
1) When I read the text, the fc_on (Forecasting hours, logical) seems to be disabled. Could you explain why? Is it my assumption correct?
2) On the other hand the forecasting hours are just only 3. Is it correct?
Thank you in advance!
Juan
Juan
21 Nov 2013 09:57 #1919
Dear Juan,
Unfortunately, your questions are beyond the scope of what I can answer here. I would guess that if forecasting is disabled, that the code would ignore the value of fc_hours.
