MSG[0]: SVAL LOOKUP ERROR trnsys.user_trdsrc
  • jptiwari
18 Oct 2013 07:37 #1884 by jptiwari
I'm getting the below error list in SAM when i try to run the simulations on my MAC OS X 10.8.4. I'm referring to a .csv weather file saved in a separate folder after adding the said folder in SAM. Even if i select a file from the SAM library and save it in this folder and try to refer, the simulation renders same errors.
MSG[1]: SVAL LOOKUP ERROR trnsys.user_exe_deck_enabled
MSG[2]: SVAL LOOKUP ERROR trnsys.user_exe_deck_enabled
MSG[3]: SVAL LOOKUP ERROR trnsys.user_exe
MSG[4]: SVAL LOOKUP ERROR trnsys.user_args
MSG[5]: TrnModel::ReadOutput[ncol=0 nalloc=8760 lnchars=3800] = 0 msec
MSG[6]: TrnModel::ReadOutput[ncol=0 nalloc=12 lnchars=2400] = 0 msec
MSG[7]: TrnModel::ReadOutput[ncol=0 nalloc=2 lnchars=1800] = 0 msec
MSG[8]: SVAL LOOKUP ERROR trnsys.target_hourly_folder
MSG[9]: TrnModel Notice: Deleting file '/Users/jptiwari/.SAMEXE/SAMEXE-jptiwari-INST1-2013.1.15/simdata/My_project/BASE/dtr.hourly.out'
MSG[10]: SVAL LOOKUP ERROR trnsys.target_hourly_folder
MSG[11]: TrnModel Notice: Deleting file '/Users/jptiwari/.SAMEXE/SAMEXE-jptiwari-INST1-2013.1.15/simdata/My_project/BASE/energy.out'
MSG[12]: TRNSYS Column 'DNI' missing for variable: system.hourly.dni
MSG[13]: TRNSYS Column 'Hour_of_day' missing for variable: system.hourly.hour_of_day
MSG[14]: TRNSYS Column 'P_atm' missing for variable: system.hourly.p_atm
MSG[15]: TRNSYS Column 'V_wind' missing for variable: system.hourly.v_wind
21 Oct 2013 11:09 #1885 by Paul Gilman
Replied by Paul Gilman on topic MSG[0]: SVAL LOOKUP ERROR trnsys.user_trdsrc
A problem with the weather file may be causing the problem. Are you using one of the standard TMY2 or TMY3 files from the NREL NSRDB database, or a file from a different source?
If you are using a file from another source, please attach it to your original message, and I will see if I can see what might be causing the problem.
  • jptiwari
30 Oct 2013 00:51 #1886 by jptiwari
Replied by jptiwari on topic MSG[0]: SVAL LOOKUP ERROR trnsys.user_trdsrc
Hi Paul!
I have attached the weather file. While it is running in Windows, it is showing the above error in IOS. Yes i'm using the standard file from NREL NSRDB database.
Best Regards
JP
01 Nov 2013 15:46 #1887 by Paul Gilman
Dear JP,
The weather file you attached does not appear to be in the correct TMY3 format. For example, the direct normal irradiance values vary from -10,000 to over 100,000. For hourly irradiance data in W/m2, I would expect the values to range from zero to around 1,000.
