PV Inverter Clipping
08 Oct 2013 10:07 #1870
PV Inverter Clipping was created by Paul Gilman
I notice that when I overload the inverter to 1.2x, it gives the following warning notice:
pvsamv1: Inverter undersized: The array output exceeded the inverter rating 512.22 kWdc for 96 hours.
Production estimate seems to be high in this scenario. Curious if it actually accounts for clipping. Any chance you could confirm?
The error message tells you the number of hours of the 8,760 hours in a year that the array's DC output exceeded the inverter's rated input power. In general, if that happens for just a few hours, you can ignore the message and assume that the system's control electronics can manage the situation (typically by operating the array off the maximum power point). You can also see what's happening on an hour-by-hour basis by plotting hourly results on the Results page. As you'll see in the hourly results, SAM does clip the inverter's output to its rated AC output power so that the inverter's output is never higher than its rated capacity.
- stumpyd123
20 Dec 2016 18:03 #1871
by stumpyd123
Replied by stumpyd123 on topic PV Inverter Clipping
Paul,
Is there a standard SAM output that measures the total kWh of AC energy clipped for the year?
David
David
- stumpyd123
20 Dec 2016 19:52 #1872
by stumpyd123
Never mind. I found it.
