Tracker Rotation Limit (deg) for PV Systems
07 Oct 2013 15:07 #1862 by Paul Gilman
Tracker Rotation Limit (deg) for PV Systems was created by Paul Gilman
Does an input of 45 degrees mean the tracker rotates 45 degrees in both directions from the centerline for a total rotation of 90 degrees, or only 22.5 degrees from centerline in each direction.
The former. A tracker rotation limit of 45 degrees means that the tracker rotates 45 degrees in both directions from the center line.
