Gap between "Solar field thermal output" and "Thermal energy to the power cycle" (in case of TES full charged)
- Suzuki Koichi
01 Oct 2013 04:50 #1847
by Suzuki Koichi
Gap between "Solar field thermal output" and "Thermal energy to the power cycle" (in case of TES full charged) was created by Suzuki Koichi
Hello.
I am trying to simulate a parabolic trough collector thermal plant with storage by ver.2013.1.15.
Could you explain the gap between "Solar field thermal output" and "Thermal energy to the power cycle” at storage full charged?
In case of no storage, "Solar field thermal output" is equal to "Thermal energy to the power cycle". Also, in case of charging to storage, "Solar field thermal output" is equal to “Thermal energy to the power cycle + Thermal energy to thermal storage".
However, when storage is full charged, it seems there is some gap between "Solar field thermal output" and "Thermal energy to the power cycle ".
I attached my output. Please explain this gap.
Koichi Suzuki
Koichi Suzuki
02 Oct 2013 16:12 #1848
Replied by Paul Gilman on topic Gap between "Solar field thermal output" and "Thermal energy to the power cycle" (in case of TES full charged)
Dear Koichi,
Would you mind attaching to your original post a copy of the .zsam file that generated the results in your spreadsheet?
To attach the file, click the Edit tab above your original post and use the options under "File Attachments" to choose and attach the file.
08 Oct 2013 09:21 #1849
Dear Koichi,
Your calculations do not account for the thermal capacitance of the HTF. In the case of the power tower, you can use a value of 2.507 kJ/kg-K for salt. For a parabolic trough, you can use 2.455 kJ/kg-K for the Therminol VP-1 oil. Please see the spreadsheet that I attached to your original message for an example.
- pavankumar001@gmail.com
21 Feb 2016 16:41 #1850
by pavankumar001@gmail.com
Replied by pavankumar001@gmail.com on topic Gap between "Solar field thermal output" and "Thermal energy to the power cycle" (in case of TES full charged)
Dear Mr Paul/Mr Koichi,
Could you please attach the zsam file and the excel spreadsheet Mr.Paul referred to ?
22 Feb 2016 09:27 - 15 Sep 2022 11:14 #1851
The files are attached.
Last edit: 15 Sep 2022 11:14 by Paul Gilman.
