We will be performing a major infrastructure and web site ugprades on Wednesday, June 11th from 3:00pm - 6:00pm MDT (UTC -6).
The website will be down during that time.
CSP Trough Empirical, Commercial - Independent Power Producer
  • Pierre
30 Jul 2013 01:11 #1728 by Pierre
Dear Sir,
I wanted to ask you which are the differences between:
"CSP Trough Empirical, Commercial" and "CSP Trough Empirical,Independent Power Producer".
I have introduced the same inputs and I have a different production of gross power.
I am working with 2013.1.15 Version.
Thank you very much.
  • Pierre
30 Jul 2013 05:07 #1729 by Pierre
Dear Sir,
I have solved this question. The difference was that with a model, I was working with 2012.11.30 and with the other, it was 2013.1.15.
When I used "CSP Trough Empirical, Commercial" and "CSP Trough Empirical,Independent Power Producer" with 2013.1.15 Version, I have the same results.
But, I have a new question. Is there a production margin applied about 5%?
30 Jul 2013 11:35 #1730 by Paul Gilman
Dear Pierre,
The "production margin" you observe may be due to the values on the Performance Adjustment page. The default cases for the empirical trough model have a "percent of annual output" factor of 96% that reduces the system's total annual output by 4% to account for system outages for maintenance or for other reasons.
You can expect the results between versions to change as we find and fix problems in the performance models. You can see a list of the differences between SAM 2012.11.30 and SAM 2013.1.15 in the release notes, which are available on the Help menu.
