We will be performing a major infrastructure and web site ugprades on Wednesday, June 11th from 3:00pm - 6:00pm MDT (UTC -6).
The website will be down during that time.
Thermal Storage. CSP Trough Physical, Commercial
  • Pierre
28 May 2013 11:23 #1642 by Pierre
I am working with 2013.1.15 version. I wanted to ask you about "Thermal Storage".
In "TES Thermal Capacity", it indicates MWt. Is it MWh? Is it correct?
I was consulting the help and in the first equation of "Storage volume", it uses "t full load". Is would not be an energy?
What temperatures use in the equation?
Thank you very much.
With best regards
07 Jun 2013 14:30 #1643 by Paul Gilman
Replied by Paul Gilman on topic Thermal Storage. CSP Trough Physical, Commercial
Dear Pierre,
Yes, those are MWh of thermal energy.
The thermal energy storage (TES) system capacity in hours is the number of hours that the TES can drive the power cycle at its rated capacity. For a power cycle with a "design gross output" capacity of 111 MWe and a rated cycle conversion efficiency of 0.3774, 6 hours of TES capacity would be:
111 MWe / 0.3774 * 6 h = 1,764 MWht
The 'e' and 't' in the capacity (MW) and energy (MWh) units indicate electricity and thermal energy, respectively.
Because this equation uses the power cycle's rated capacity, you can assume that the temperature would be at the cycle's design inlet temperature.
