Generic Solar System. Time step
  • Pierre
16 May 2013 01:19 #1620 by Pierre
Generic Solar System. Time step was created by Pierre
I have a question about Generic Solar System. I am working with 2013.1.15 version.
If you go to Analysis -> Simulator Options
The time step is "1hr". If I use a different step like 30 minutes, or 10 minutes, the production of energy will be different.
Is this possible? Why?
Best regards
16 May 2013 13:45 #1621 by Paul Gilman
Replied by Paul Gilman on topic Generic Solar System. Time step
Dear Pierre,
You should only change the simulation time step if you have weather data in a time step other than 60 minutes. If you change the simulation time step to 30 minutes and then run simulations with 60 minute (hourly) data, SAM will misinterpret the data in the weather file.
Only the physical trough model has been tested to run with weather data with time steps other than 60 minutes. We do not recommend changing the simulation time step unless you are using the physical trough model, and have weather data to match the simulation time step.
