Clarity on SAM terms
  • Abhishek
21 Jan 2026 06:59 #14466 by Abhishek
Clarity on SAM terms was created by Abhishek
I have been facing issue with understanding the terms 'Parasitic power generation-dependent load' and 'Parasitic power fixed load'. They are given in the SAM simulation results, but there have not been any explanation for these parameters.
Along with that, I am also doubtful whether these parameters are somehow connected to 'Balance of plant parasitic load', 'Auxillary heater boiler parasitic load', and 'adjustment factor'. It would be great if we can get the explanations for these parameters too.
Is there any parameter in SAM which gives us the system pressure in the plant?
Also explain all the terms so that I don't get confused
26 Jan 2026 10:46 #14469 by Paul Gilman
Replied by Paul Gilman on topic Clarity on SAM terms
Hi Abhishek,
I assume these questions are about the CSP physical trough model.
"Parasitic power generation-dependent load" accounts for electricity required for parasitic loads that vary with the output of the system, such as for HTF pumps.
"Parasitic power fixed load" accounts for electricity for parasitic loads that are constant.
"Balance of plant parasitic load" and "Auxillary heater boiler parasitic load" are calculated from the inputs at the top of the System Control page.
There is not an output variable called "adjustment factor," but that term is generally associated with the "System Availability" inputs, which for the physical trough model are on the System Control page.
The physical trough model reports the pressure for various parts of the system. There is not an overall system pressure variable.
