issue in field pressure drop and field optical end loss.
- Abhishek
20 Jan 2026 06:21 #14458
by Abhishek
issue in field pressure drop and field optical end loss. was created by Abhishek
While reviewing the simulation results of a CSP parabolic trough system using the Physical Model in SAM, I observed an aspect that I am finding difficult to interpret and would appreciate your guidance on.
At certain time stamps in the results, the reported resource pressure appears to be lower than the corresponding field pressure drop. Conceptually, my understanding is that for the heat transfer fluid to be successfully pumped through the solar field, the available resource (or pump outlet) pressure should be higher than the total pressure drop across the field. Otherwise, the fluid should not be able to flow through the system.
However, despite observing instances where the resource pressure is lower than the field pressure drop, the simulation runs without any errors or warnings. This has led to some confusion regarding whether this is actually an error on SAM's side or I am conceptually wrong.
While analyzing the results of a CSP parabolic trough workfile, I came across the term “Field Optical End Loss” in the data table section after the simulation. I am finding it difficult to clearly understand the physical meaning of this term and how it is evaluated within SAM, and why its value is around 0.9, although it is a loss.
regards,
Abhishek Meena
regards,
Abhishek Meena
20 Jan 2026 10:05 #14459
Replied by Paul Gilman on topic issue in field pressure drop and field optical end loss.
Hi Abhishek,
The "Resource Pressure (mbar)" output variable is the atmospheric pressure value from the weather file, not a pressure drop in the system.
The "end loss" label is misleading: That variable is a factor rather than a reduction, so a value of 0.9 would be equivalent to a 10% reduction. The equations for that value are here in the SSC source code:
The end loss:
github.com/NREL/ssc/blob/0a05b2dfa33c325ff59f00e97a3c84122ec0a542/tcs/csp_solver_trough_collector_receiver.cpp#L1854
The average end loss is the value that SAM reports in the results:
github.com/NREL/ssc/blob/0a05b2dfa33c325ff59f00e97a3c84122ec0a542/tcs/csp_solver_trough_collector_receiver.cpp#L1888
The end loss:
