Voltage Tracking Window
- inreco
21 Dec 2025 08:09 #14425
by inreco
Voltage Tracking Window was created by inreco
After running "System Sizing" macro, I get a yellow message window saying "Notice: Inverter MPPT voltage tracking window not defined - modules always operate at MPPT.
I manually entered Inverter specs from a data sheet.
What does the message mean?
05 Jan 2026 10:26 #14436
Replied by Paul Gilman on topic Voltage Tracking Window
The message "Inverter MPPT voltage tracking window not defined - modules always operate at MPPT" may indicate that the MPPT voltage ratings on the Inverter page are incorrect. For example, SAM generates the error when the minimum MPPT voltage rating is greater than the maximum MPPT voltage rating.
- inreco
05 Jan 2026 12:55 #14441
by inreco
Replied by inreco on topic Voltage Tracking Window
This particular Inverter was selected from SAM's "Inverter CEC Database" Why the error? What other input changes would eliminate that notice?
07 Jan 2026 13:16 #14447
It's hard for me to know without seeing the file.
It's possible there is an error in the parameters stored in the library for the inverter you selected, or that someone changed the inverter voltage ratings on the System Design page after choosing the inverter from the library on the Inverter page.
