Regarding Solar multiple
- Abhishek
28 Nov 2025 23:20 #14394
by Abhishek
Regarding Solar multiple was created by Abhishek
In SAM for the PTC, when we are calculating solar multiple then we need two values 1) cycle thermal power and 2) field thermal power w/o defocus constraints.
I know how to calculate cycle thermal power but I couldn't understand how you calculated the field thermal power w/o defocus constraints.
I attached a image in that when I put the values of the DNI is 600 w/m2 and aperture area 8175 m2, so the solar energy is 4.905 MW then how they convert it into 3.58. Explain me ?
I also checked the code but noting is related in the code for this.
Abhishek Meena
IIT Bombay
Abhishek Meena
IIT Bombay
01 Dec 2025 10:07 #14395
Replied by Paul Gilman on topic Regarding Solar multiple
Hi Abhishek,
For SAM's physical trough model, the "Cycle thermal power" shown on the System Design page is 'q_cycle_des', calculated here: github.com/NREL/ssc/blob/ce1a12f6f9f57e95a9f311799228896e35cb592d/ssc/cmod_trough_physical.cpp#L899 .
The "Field thermal power w/o defocus constraints" is 'm_q_design_idea', calculated here: github.com/NREL/ssc/blob/ce1a12f6f9f57e95a9f311799228896e35cb592d/tcs/csp_solver_trough_collector_receiver.cpp#L601 .
