the effect of cloudy weather on the energy production of a photovoltaic system
  • samin
30 Oct 2025 10:03 #14355 by samin
Hi!
To analyze the effect of cloudy weather on the energy production of a photovoltaic system — either within the parametric analysis section or any other module — which input variable should be used?
I could not find a direct parameter for this purpose, so I would appreciate your guidance.
Best regards
Samin Roshan
30 Oct 2025 13:51 #14356 by Paul Gilman
Hi Samin,
In SAM, the effect of weather on the production of a PV system is determined by the data in the weather file. SAM's PV performance models require a weather file with information about the solar irradiance, ambient temperature, and wind speed. The solar irradiance data in the file accounts for the effect of clouds: The daytime direct normal irradiance (DNI) is less on a cloudy day than a clear day.
To see the effect of clouds on the system's performance, you could compare the electrical output of the system on a clear day with the output on a cloudy day. You can use the "Irradiance DNI from weather file (W/m2)" and "System power generated (kW)" output variables to see this effect. For example, this plot shows two clear days followed by two cloudy days:
