Inverter Datasheet
- inreco
26 Oct 2025 12:33 #14343
by inreco
Inverter Datasheet was created by inreco
None of the pertinent titles of GE's data sheet match your input page (Datasheet) without having to do various calculations and not knowing if they are correct. Because I get errors after "Simulate and Sizing Macro". I can't copy and past the errors because your site doesn't allow it. I have an .ond file from GE, can I plug it into SAM? I attached GE's Date Sheet and maybe you can translate your 'Datasheet" input language to industry standard language so I don't have to do exhaustive calculations and finally move forward with my project.
28 Oct 2025 09:25 #14346
Replied by Paul Gilman on topic Inverter Datasheet
Please see this post for a description of the "PVsyst OND - PAN to SAM" macro, which you can use to import data from PVsyst PAN files for PV modules or OND files for inverters into SAM: sam.nrel.gov/index.php?option=com_kunena&view=topic&catid=5&id=3386&Itemid=487#9428 .
