General to inlet temperature related issue
  • Abhishek
06 Aug 2025 06:20 #14207 by Abhishek
Hey,
Abhishek this side I have the problem regarding the inlet temperature.
I am working on the 1MWe solar thermal power plant Gurgaon, Haryana.
I attached a image and a SAM file below. Can you explain me about why this graph line is going to 260(+) to 240(+) decreasing for 00.00 AM to 07.00 AM and same issue after the 18 PM. it should be constant between these times but this is not constant why?
And If I want to constant the inlet temperature how to do this ?
 I also want to know in the SAM software is only depends on what ? (like PTC, turbine, steam generator etc.)
Another that I want to know is there any parameter in the SAM that can be controlling the defocus part ?
