Wave resource Simulation
- Veronica Dabrowski
21 Jan 2025 06:05 #13822
by Veronica Dabrowski
Wave resource Simulation was created by Veronica Dabrowski
Hello
I would like to simulate the wave resources of a location in Norway. I have adapted the data to the format required by SAM but the file is still not working. I am not able to add the file to the library to simulate the resource.
Could you please check the file and let me know if something is missing or has to be corrected.
Veronica
Veronica
21 Jan 2025 09:59 #13823
Replied by Paul Gilman on topic Wave resource Simulation
21 Jan 2025 11:59 #13825
Replied by Veronica Dabrowski on topic Wave resource Simulation
21 Jan 2025 17:19 #13826
Hi Veronica,
Thank you for following up. I made a mistake in my testing -- you are correct that your file does not work with SAM's Wave model.
The problem is the Location ID field in the header. For some reason SAM requires that the field be a number. Please try changing the location ID from "SN76923" to a number like "76923". In my testing, that fixed the problem.
We will fix this in an update: github.com/NREL/SAM/issues/1994 .
22 Jan 2025 01:03 #13827
Hi Paul
Now it works.
Thank you!
Now it works.
Thank you!
