DATA for other countries
- Lindani
04 Apr 2013 01:37 #1511
by Lindani
DATA for other countries was created by Lindani
hi
does anyone know how i can include weather data for my country? do i have to literally create the source files or there is a way that i can download the add ons?
- mpoliafico
04 Apr 2013 06:11 #1512
by mpoliafico
Replied by mpoliafico on topic DATA for other countries
I generally use the following process:
A. Location and Resource screen (the initial one)
B. Link at the bottom part of the page --> "Best weather data for international locations (in EPW format)
C. That link opens the following page: apps1.eere.energy.gov/buildings/energyplus/weatherdata_about.cfm?CFID=246227&CFTOKEN=f5999158c904bd9d-D4F121D3-9411-8DF0-204E47910DD4ECFB
D. Browse and check if you find a suitable location
E. Download the file somewhere (e.g. desktop)
F. Use the first button under the list of locations on the screen "Folder Settings" and follow instructions to add a folder (e.g. the desktop)
G. Second button "Refresh list" should bring that file into the list of location (look it up at the bottom)
There might be other and better ways, this is what I do.
Hope it helps
Renewable Regards
Marco Poliafico
Hope it helps
Renewable Regards
Marco Poliafico
05 Apr 2013 12:33 #1513
Replied by Paul Gilman on topic DATA for other countries
Thanks Marco. Your instructions are correct.
If you cannot find weather data for your location on the EnergyPlus website and you have access to weather data with all of the fields that SAM requires, you can use SAM's TMY3 Creator to use the data in SAM.
- davidlitt
07 Apr 2013 17:44 #1514
by davidlitt
Replied by davidlitt on topic DATA for other countries
Has any one had any luck importing the Japanese NEDO data from METPV or MONSOLA databases into a format that can be used under SAM?
NEDO has very detailed data for hundreds of points within Japan over 20-30 years ... and it would be nice to be able to use it with SAM instead of relying on a few data points that EnergyPlus lists in IWEC (or the few data points that Weather Analytics sells).
www.nedo.go.jp/library/nissharyou.html
David Litt
David Litt
- GeoModel Solar
16 Apr 2013 04:07 #1515
by GeoModel Solar
Replied by GeoModel Solar on topic DATA for other countries
Hi David,
A new alternative for weather data for Japan is SolarGIS (which can be made available in SAM weather data format). SolarGIS data for Pacific region has only become available since yesterday. The data has a primary spatial resolution of 4km x 4km, which is further enahnced to 250 m x 250 m using high resolution digital terrain model. As of now 6 years of data is available (July 2006 onwards)..but this will be extended to 13+ years after few months. More info here: solargis.com/support/knowledge-base/
You can let me know if you have any questions about SolarGIS data
