Simulation failure (CSP)
- Pedro
16 Sep 2024 11:47 - 17 Sep 2024 16:27 #13438
by Pedro
Simulation failure (CSP) was created by Pedro
Hello dear users of SAM
Today I have been using SAM to try simulate the CSP Gemasolar located in Spain. When I have finished filling all the paramenters and I have clicked on the Simulate bottom, then SAM has generated the following message:
I was wondering if someone could help me to solve this problem, because I am not an expert using SAM.
So, any thoughts on what is going wrong?
Thanks so much
Kind regards, Pedro
Thanks so much
Kind regards, Pedro
Last edit: 17 Sep 2024 16:27 by Paul Gilman. Reason: Please attach images as files and then insert them into your message
17 Sep 2024 16:33 #13443
Replied by Paul Gilman on topic Simulation failure (CSP)
Hi Pedro,
That error message indicates that the simulation failed, but it is unclear why.
Please attach a copy of your .sam file if you would like help troubleshooting.
You might also try searching the forum (use the Search box at the top right) for "gemasolar" to find other posts on the topic.
- Pedro
18 Sep 2024 12:05 #13446
by Pedro
Replied by Pedro on topic Simulation failure (CSP)
Hi Paul
Thanks so much for answering my question, I've attached the file in this message, also I'm gonna search in the forum this issue.
In addition, if you find anything worng, I will really apreciate you that write me.
Kind regards.
Pedro
Kind regards.
Pedro
19 Sep 2024 10:17 #13447
Hi Pedro,
Attached is a version of the file from sam.nrel.gov/concentrating-solar-power/csp-validation.html that should work in SAM 2023.12.17.
When you download a weather file on the Location and Resource page, I would recommend using either the latitude and longitude of the project site as the location, or its street address. If you simply use "gemasolar" you may get a weather file for the wrong location.
