CEC Module Database Attribute Confusion
- William Maxwell
12 Sep 2024 10:01 #13427
by William Maxwell
CEC Module Database Attribute Confusion was created by William Maxwell
When looking through the CEC Performance Model with Module Database, is there an available description of the column headers from "alpha_sc" through to "gamma_r" in the red box in the attached image? What do each of these parameters represent?
Similarly, where are the Nominal Efficiency and Temperature Coefficients being pulled from? When I open up the CEC Modules.csv file I dont see either parameter in there. Are they being calculated from other parameters? If so, which ones using which formulas? Thanks!
12 Sep 2024 17:12 - 16 Sep 2024 09:55 #13429
Replied by Paul Gilman on topic CEC Module Database Attribute Confusion
The 'alpha_sc' parameter is the temperature coefficient of short circuit current in A/°C. For the module in your screenshot, the value in the library is 0.00297882, and is shown in the blue cell on the Module page rounded to 0.003.
Similarly, 'beta_oc' is the temperature coefficient of open circuit voltage in V/°C, and 'gamma_r' is the temperature coefficient of power in %/°C. The nominal operating cell temperature (shown in blue under "Temperature Correction") in °C is 'T_NOCT'.
The 'beta_oc', 'alpha_sc', and 'gamma_r' parameters can be expressed either in V/°C, A/°C or W/°C, respectively, or %/°C. For example, to convert the 'gamma_r' value -0.457 %/°C to W/°C, multiply 'gamma_r' by 'Pmp': -0.457 %/°C * 300.120 W / 100 % = -1.373 W. For 'beta_oc', multiply by 'Voc', and for 'alpha_isc', multiply by 'Isc'.
The remaining parameters, 'a_ref', 'I_L_ref', 'I_o_ref', 'R_s', 'R_sh_ref', and 'Adjust' are coefficents of equations in the modified 6-parameter single diode module model, which in SAM is called the "CEC Performance Model". These coefficients are not provided in the module list from the California Energy Commission . We calculate those coefficients for SAM's module library using the tools provided here in the SAM GitHub repository . Calculating the coefficients from the database parameters requires a mathematical solver -- these are not calculated using simple equations.
The nominal efficiency is the module's conversion efficiency at standard test conditions. It is calculated as follows:
eff = ( Vmp * Imp ) / ( 1000 W/m2 * A )
where
eff = module nominal efficiency
Vmp = voltage at maximum power at standard test conditions (STC) in VDC
Imp = current at maximum power at STC in A
1000 W/m2 = irradiance at STC
A = module area in m2 (from the library and shown at the bottom of the Module page)
where
Last edit: 16 Sep 2024 09:55 by Paul Gilman.
- William Maxwell
13 Sep 2024 11:24 #13433
by William Maxwell
Replied by William Maxwell on topic CEC Module Database Attribute Confusion
Paul, thanks for the detailed explanation.
