SAM Parametric on multiple imported field layouts
- Harry Morgan
20 Aug 2024 19:37 #13398
by Harry Morgan
SAM Parametric on multiple imported field layouts was created by Harry Morgan
I have generated 11 different field layouts in solarPILOT. I was wondering whether it is possible to run a parametric on these in SAM or whether I have to do this manually.
Harry
Harry
21 Aug 2024 07:54 #13399
Replied by Paul Gilman on topic SAM Parametric on multiple imported field layouts
Hi Harry,
It should be possible to run a parametric simulation for the set of input variables from SolarPILOT, but I think it would be easier to troubleshoot running the simulations separately. Running separate simulations also gives you easier access to all of the outputs for each case.
