How to down load Wind data files for Indian site
  • N S PRASAD
01 Aug 2024 03:48 #13359 by N S PRASAD
Pls inform " how to down load Wind resource data files for Indian sites? ."
Thanks and Regards
Prasad NS,
01 Aug 2024 12:30 #13361 by Paul Gilman
Replied by Paul Gilman on topic How to down load Wind data files for Indian site
Hi Prasad NS,
You can download wind resource data for locations in India from the NREL Developer Network India Wind Toolkit Data Downloads API:
developer.nrel.gov/docs/wind/wind-toolkit/india-wind-download/
To use the API, you will need to sign up for an API key for the NREL Developer Network:
developer.nrel.gov/signup/
Unfortunately, the file format used by the API is different from the file format required by SAM's Wind Power model, so you will need to reformat the data for it to work. See SAM Help for a description of the SAM CSV Format for Wind:
samrepo.nrelcloud.org/help/weather_format_csv_wind.html
  • N S PRASAD
04 Aug 2024 05:09 #13363 by N S PRASAD
Replied by N S PRASAD on topic How to down load Wind data files for Indian site
Thanks.
Following your guidance got the API key. Got into the following India (/api/wind-toolkit/v2/wind/india-wind-download)
However, after entering the URL and "Request for parameters." it is not moving ahead. An email needs to be received , as explained therein, But not getting the email and proceeding further.
Request you to pls look into and revert.
NS Prasad
05 Aug 2024 11:17 #13369 by Paul Gilman
Hi NS Prasad,
Here is an example of a URL that should result in a file download directly to your computer. You can try it in a web browser after replacing the placeholders with your email address and API key.:
developer.nrel.gov/api/wind-toolkit/v2/wind/india-wind-download.csv?wkt=POINT (75.36621 24.726874)&names=2014&email=&leap_day=false&utc=false&interval=60&api_key=
After you download the CSV file, if you want to use it with SAM's Wind Power model, you will need to modify it so that it meets the requirements described in the "SAM CSV Format for Wind" topic in SAM's Help system: samrepo.nrelcloud.org/help/weather_format_csv_wind.html .
