Battery State of Charge Question
  • Patrick Muha
19 Jul 2024 14:05 #13333 by Patrick Muha
Battery State of Charge Question was created by Patrick Muha
 I'm modeling my home system which has is an off-grid 19.2 kW array and 60 kWh of batteries. When I set up the configuration in SAM and run a simulation I see the batteries drain from 100% to 10% with only 3-4 kWh of load drawn. In practice I see this 3-4 kWh represent about a 5% charge reduction rather than the 90% that the model suggests. Is there something wrong in my model configuration?
Thank You!
Pat
22 Jul 2024 16:51 #13337 by Paul Gilman
Replied by Paul Gilman on topic Battery State of Charge Question
Hi Pat,
I think this is because you set the cell nominal voltage and cell capacity to values for the battery bank, but are using the voltage discharge curve for a single cell.
In the attached file, I created a copy of your case but reset the battery inputs to the default values for a Li-ion LFP battery, and the resulting battery state of charge seems more in line with what you expect.
(You will need to select your weather file from the Location and Resource page when you open the attached .sam file because it currently points to a weather file on my computer.)
  • Patrick Muha
22 Jul 2024 20:23 #13339 by Patrick Muha
Replied by Patrick Muha on topic Battery State of Charge Question
Thanks Paul, this looks great now!
