Solar Self-Sufficiency Metric in PySAM and/or SAM
- Seif
05 Jul 2024 19:24 #13279
by Seif
Solar Self-Sufficiency Metric in PySAM and/or SAM was created by Seif
I wanted to ask if SAM has a built-in self-sufficiency metric, and if yes whether it is implemented in PySAM (preferably PVWatts for both). I searched documentation as well as the forum and found no similar metric or how one could leverage already existing outputs to calculate this. I realize that a rough estimate could be found by dividing energy produced by PV/energy required by facility, but if the system does not have an installed battery and the electricity supply and demand profile curves don't match, then that rough estimate becomes highly inaccurate.
NB. Self sufficiency in this case is defined as: "how much of the consumed energy, came from the photovoltaic system."
09 Jul 2024 11:18 #13288
Replied by Paul Gilman on topic Solar Self-Sufficiency Metric in PySAM and/or SAM
SAM's PV models do not report a self-sufficiency metric.
For either PVWatts or Detailed PV without storage combined with wither the Residential or Commercial financial model, you can use the time series "Electricity from system to load (year 1 hourly) (kWh)" and "Electricity load (year 1) (kW)" outputs to determine how much of the load is met by the PV system.
- ashasharmaads16@gmail.com
11 Jul 2024 01:08 #13296
by ashasharmaads16@gmail.com
Replied by ashasharmaads16@gmail.com on topic Solar Self-Sufficiency Metric in PySAM and/or SAM
No, SAM does not have a built-in self-sufficiency metric, and it is not implemented in PySAM, including PVWatts. You would need to calculate it manually by comparing hourly PV production with hourly facility consumption.
