Please help with cec_n_s error.
- Benjamin Liu
10 May 2024 14:14 #13158
by Benjamin Liu
Please help with cec_n_s error. was created by Benjamin Liu
Dear SAM,
Please help me troubleshoot the following error when I run the simulation:
cec_n_s:fail(cec_n_s, positive): -1
Simulation pvsamv1 failed :cec_n_s:fail(cec_n_s, positive): -1
gen not assigned
Many thanks,
Ben
gen not assigned
Many thanks,
Ben
13 May 2024 16:49 #13161
Replied by Paul Gilman on topic Please help with cec_n_s error.
Hi Ben,
This error is caused by the library error on the Module page:
To fix the problem:
To fix the problem:
- Open the "Eldorado IL.sam" file and go to the Module page.
- At the top of the page, switch from CEC Performance model with User Entered Specifications to CEC Perfomance Model with Module Database.
- When you see the error "Error: '' is not available in the library. Choose a different item." error, click OK. You may need to click it two or three times.
- Choose any module in the library.
- Switch back to CEC Perfomance Model with Module Database.
