Thoothukudi Tamil Nadu India - NREL data selected in under Wind Resource
- N S PRASAD
17 Apr 2024 10:02 #13090
by N S PRASAD
Thoothukudi Tamil Nadu India - NREL data selected in under Wind Resource was created by N S PRASAD
Dear Mr. Gilman,
The module shows height error
C:\Users\ns.prasad\Downloads\image (2).png Your data is ready! Please click the link below to download your file. This link will remain valid for 24 hours.[url] mapfiles.nrel.gov/data/wind/01e7f1e7858a6c887c12791af22da80d.zip [/url]
Pls see and suggest.
Prasad NS
Prasad NS
17 Apr 2024 13:40 #13093
Replied by Paul Gilman on topic Thoothukudi Tamil Nadu India - NREL data selected in under Wind Resource
Hi Prasad,
SAM's wind power model requires that the wind resource file have wind speed data measured at a height within 35 meters of the turbine hub height. You should be able to fix this problem by adjusting the turbine hub height on the Turbine input page, or downloading wind resource data with data at the appropriate height. SAM will interpolate wind resource data as needed, so if your wind resource file has data at 80 meters and the hub height is 100 meters, SAM adjusts the wind resource data accordingly.
