Display payback value in summary tab
- Njabulo Mlilo
05 Apr 2024 03:01 #13060
by Njabulo Mlilo
Display payback value in summary tab was created by Njabulo Mlilo
Pease advise how I can re-configure the summary results table to display pay back value for Merchant Plant model. If summary table can not be modified, please advise any other way to read payback values for simulations
Regards
Njabulo Mlilo
Regards
Njabulo Mlilo
05 Apr 2024 10:00 #13061
Replied by Paul Gilman on topic Display payback value in summary tab
Hi Njabulo,
It is not possible to configure the Summary tab on the Results page. You can move graphs around on the page, but it is not possible to change the variables that appear in the Metrics table or to add and remove graphs: samrepo.nrelcloud.org/help/summary.html
You can use the Data Tables tab to see all available metrics and outputs in a table.
SAM's Merchant Plant financial model does not report a payback period. For these projects, the key metrics are net present value, internal rate of return, and size of debt.
- Njabulo Mlilo
28 May 2024 09:01 #13209
by Njabulo Mlilo
Replied by Njabulo Mlilo on topic Display payback value in summary tab
Thanks Paul
regards
Njabulo
regards
Njabulo
