geothermal stochastic
  • Feifei
19 Mar 2024 15:12 #13000 by Feifei
geothermal stochastic was created by Feifei
Hi SAM,
I am interested to run the GETEM in SAM.
I have downloaded the software and do the tests.
I tried to run "Stochastic" for Geothermal simulation one simple owner. like I only chose:
input: "Reservoir Temperature"
output: "Energy produced in Year TOP period 1"
Then click "Run simulations", it will crash, and the software will all close and exit.
I tried to set other output, seems like all will crash.
Can you help to solve the issue?
Feifei
20 Mar 2024 17:22 #13011 by Paul Gilman
Replied by Paul Gilman on topic geothermal stochastic
Hi Feifei,
I don't see "Reservoir temperature" as an available input for Stochastic simulations:
However, I was able to replicate the crash with other input variables.
The Geothermal model is not well suited to stochastic simulations. You may want to try changing input variables and running simulations manually.
