Developer Metrics NaN and Host Metrics Negative
- Michael Caballero
14 Mar 2024 11:45 #12984
by Michael Caballero
Developer Metrics NaN and Host Metrics Negative was created by Michael Caballero
Hi Paul
I'm trying to create a solar plus storage microgrid that can handle a yearly power generation of 3.7 MW. After inputting the system parameters and simulating I'm receiving notes that the rate of return in NaN and the host revenue is negative:
IRR at end of analysis period is not a number (NaN). This can indicate that revenues are too low to cover costs, or that they are excessively high compared to costs.
IRR in target year is not a number (NaN). This can indicate that revenues are too low to cover costs, or that they are excessively high compared to costs.
Debt percent is 125.944. A debt percent greater than 100% may indicate that revenues are higher than necessary to cover project costs.
From the simulation I believe the nominal rate of the systems electricity is lower than the GSD rate I entered (though I'm still getting the hang of understanding the outputs) so I'm wondering if I made a mistake or if the size/cost of the system is just too big to be financially beneficial. I've attached the SAM file.
Thank so much for your help!
Best,
Michael
Best,
Michael
15 Mar 2024 11:08 #12987
Replied by Paul Gilman on topic Developer Metrics NaN and Host Metrics Negative
Hi Michael,
There are a couple of of metrics indicating that the project is not economically feasible given your assumptions:
Developer IRR = NaN
Debt percent > 100%
Host NPV < 0
You can explore the cash flow details on the Cash Flow tab to better understand what the financial model is doing.
I would review the inputs on the Financial Parameters page to see if they are what you expect.
Developer IRR = NaN
Debt percent > 100%
Host NPV < 0
- Discount rate represents value of alternative investment and is used to calculate the NPV.
- DSCR (debt service coverage ratio) -- this value is typically one required by the loan provider. The DSCR option automatically sizes debt based on revenue available for debt service. If you aren't sure about DSCR, you can use the debt percent option to size the debt as a percentage of the total installed cost.
- Debt closing cost, up-front fee, and construction financing cost are in addition to the total installed to calculate the total capital cost.
- Reserve accounts are funded and disbursed throughout the analysis period.
- Michael Caballero
15 Mar 2024 13:33 #12988
Replied by Michael Caballero on topic Developer Metrics NaN and Host Metrics Negative
I changed the project term to debt percent and reduce the fed income tax from default and was able to get results with real values.
The goal of the study is to create a system that reduces grid energy utilization so the financials are secondary but I still wanted to get cost metrics and a reasonable LCOE per kWh to compare to the rates from the grid so this has helped.
Thanks!
Michael
Thanks!
Michael
- Michael Caballero
17 Mar 2024 15:25 #12992
Thanks Paul. I was able to update some of those metrics and selected the debt percentage option and was able to get values.
Michael
Michael
