Location Lookup: Failed to download the 10 km satellite data weather file from NREL for your location
  • ivan.lafrinere@gmail.com
13 Mar 2013 23:08 #1435 by ivan.lafrinere@gmail.com
When running Location Lookup for PVWatts Photovoltaic Commercial - I receive the below error, which did not occur during previous use. Can you please advise how to resolve this error?
Message
Failed to download the 10 km satellite data weather file from NREL for your location.
OK
  • cap
14 Mar 2013 12:11 #1436 by cap
I've had the same issue in the past couple of days. Any help in this regard would be much appreciated. Thanks in advance.
21 Mar 2013 13:12 #1437 by Paul Gilman
SAM uses a Google API to determine latitude and longitude values from location names and addresses. Google has made some changes to the API so that SAM's current calls to the API do not work. We are working to resolve this issue. In the meantime, you should be able to download weather files from the NREL Solar Prospector website and copy them to your weather file folder .
