Flux map for import vs. flux map intensities
  • Harry Morgan
16 Jan 2024 18:54 #12822 by Harry Morgan
Flux map for import vs. flux map intensities was created by Harry Morgan
Could please clear up the difference between the flux map intensities and the flux map for import within the SPT results? Very different values are present for each and I am wondering what this difference is?
Could you please also advice how these values could be used going forward? thank you
Kind regards,
Harry
  • Ty Neises
23 Feb 2024 14:22 - 23 Feb 2024 14:27 #12941 by Ty Neises
Replied by Ty Neises on topic Flux map for import vs. flux map intensities
Hi Harry,
“Flux map intensities” shows for various solar positions (rows) the average incident flux on each panel at the design DNI. This information can help users understand flux patterns and the location and intensity of max flux.
“Flux map for import” is an output that we use as an input to our scripts when we want to bypass the SolarPILOT call at the beginning of the simulation by using a pre-populated flux map. It is in different units because the interface between SolarPILOT and SAM uses normalized values.
Last edit: 23 Feb 2024 14:27 by Paul Gilman.
