Heliostat field ERROR Molten Salt Tower IPH
- Harry Morgan
04 Jan 2024 11:20 #12800
by Harry Morgan
Heliostat field ERROR Molten Salt Tower IPH was created by Harry Morgan
When trying to either generate or optimise my heliostat field for my model of a solar power tower, industrial process heat case in the latest version of SAM, I get this error:
Could not evaluate callback function:btn_optimize->on_change
[61]:failed to evaluate function call argument number 2, value = plant_spec_cost
[19]: eval error in statement lis
t[19]: error inside function call
How can I fix this? Thank you for your time.
I have attached the case file.
Kind regards,
Harry
Kind regards,
Harry
04 Jan 2024 20:30 #12804
Replied by Paul Gilman on topic Heliostat field ERROR Molten Salt Tower IPH
Hi Harry,
This looks like a bug in SAM 2023.12.17.
Please see this GitHub issue to track our progress fixing it: github.com/NREL/SAM/issues/1672
- Harry Morgan
05 Jan 2024 07:18 #12807
by Harry Morgan
Replied by Harry Morgan on topic Heliostat field ERROR Molten Salt Tower IPH
Thank you for addressing the issue and starting a fix.
Roughly how long do these fixes tend to take i.e. days or weeks?
Just trying to work out whether its worth moving onto a standard CSP model and just adjusting some inputs.
Kind regards
Harry
Kind regards
Harry
18 Jan 2024 12:13 #12831
Hi Harry,
We are working on an update to SAM 2023.12.17 that we expect to release in mid-February.
These kinds of bugs generally take weeks or months for us to fix and then release an update.
- Harry Morgan
18 Jan 2024 14:31 #12835
by Harry Morgan
Thank you!
Just thought I would let you know that I was able to work around this by generating a layout in SolarPILOT and exporting it to SAM. The annual simulations seem to then work.
I do seem to be having a slight issue with SolarPILOT however, where, when I run a full annual simulation to generate a heliostat field, the green progress bar goes to completion and the entire 8760 hours seem to have run, but the programme freezes anjd crashes each time before any sort of layout appears. I have deleted and reinstalled the software to no avail. I'm not sure if you cover SolarPILOT in these forums?
Harry
Thank you!
Harry
19 Jan 2024 15:58 #12842
Hi Harry,
We don't provide support for SolarPILOT on this forum. You can send an email using the "Contact information" link on the SolarPILOT website: www.nrel.gov/csp/solarpilot.html
I'm not sure work on SolarPILOT is currently being funded -- it looks like the last code commit was June 2023: github.com/NREL/SolarPILOT/issues
I'll ask around and see if I can get more information and report back here if I learn more.
